Coreform Cubit Data Translators
Your analysis depends on your CAD
High-quality data interoperability is important when using CAD for analysis. Cleaner data exchange means less need for geometry cleanup and decomposition, and that translates into lower cost and faster time to market.
Coreform Cubit Data Translators automatically repair geometry and topology, and perform tolerance resolution. With the Coreform Cubit Data Translators, there is no need to purchase expensive native programs.
Included in Coreform Cubit
Coreform Cubit supports many geometry and mesh file formats. Supported formats include:
| File Format | File Extension | Import/Export | Supported Versions |
| ANSYS | (*.*) | Export mesh and BCs | |
| ANSYS | (*.cdb) | Export mesh | 16.0-17.0 |
| Abaqus | (*.inp) | Import and export mesh and BCs | |
| ACIS† | (*.sat, *.sab) | Import and export geometry | R1-R25 |
| AVS | (*.avs) | Import geometry only | |
| CUBIT | (*.cub) | Import and export mesh and BCs | All |
| Exodus | (*.e, *.exo) | Import and export mesh and BCs | |
| Facets | (*.fac) | Import and export geometry | |
| Fluent | (*.msh) | Import and export mesh | |
| GAMBIT | (*.dbs) | Import geometry only | |
| Genesis | (*.g, *.gen) | Import and export mesh and BCs | |
| I-DEAS | (*.unv) | Import and export mesh | |
| IMPETUS | (*.k*) | Import and export mesh | |
| LS-DYNA | (*.k) | Export mesh | |
| Nastran | (*.bdf) | Import and export mesh | Simcenter Nastran only |
| OpenFOAM | Export mesh only | ||
| Patran | (*.pat, *.neu, *.out) | Import mesh and export mesh and BCs | |
| STEP† | (*.stp, *.step) | Import and export geometry | 203, 214 |
| STL | (*.stl) | Import and export geometry | All |
| UCD | (*.ucd) | Export mesh |
† Indicates that the Cubit Data Translator is based on Spatial Corporation’s 3D InterOp.
Optional Coreform Cubit data translators
Coreform offers several optional Cubit Data Translators that provide the highest quality data exchange between CAD formats. Cubit Data Translators are a cost effective way to significantly reduce your geometry preparation time and are based on Spatial Corporation’s 3D InterOp.
| File Format | File Extension | Import | Export | Supported Versions | Linux | Windows |
| IGES | *.igs, *.iges | ✓ | ✓ | Up to 5.3 | ✓ | ✓ |
| SolidWorks | *.sldprt, *.sldasm | ✓ | 98-2023 | ✓ | ||
| Parasolid | *.x_t, *.x_b | ✓ | 9.0-35.0.149 | ✓ | ✓ | |
| Pro/E / Creo | *.prt, *.asm | ✓ | 16-Creo 9.0 | ✓ | ✓ | |
| CATIA v5 | *.CATPart, *.CATProduct | ✓ | ✓ | V5 R8 to V5-6 R2023 | ✓ | ✓ |
| NX | *.prt | ✓ | 11 to NX 2212 | ✓ | ✓ |
Contact Coreform for pricing and licensing information for the optional Cubit Data Translators.
