Key Press Commands for the GUI
Several commands have a key press shortcut. These commands will be executed with respect to the currently selected entities; see the following table:
Shortcut Key
Command
l
List information about the current entity to the output window.
i
Toggle the visibility of the selected entity (make invisible or visible).
e
Echo entity id to command line.
Select the next entity.
Select the previous entity.
0
Toggle picking of vertices.
1
Toggle picking of curves.
2
Toggle picking of surfaces.
3
Toggle picking of volumes.
4
Toggle picking of groups.
shift_key.gif 0
Toggle picking of mesh nodes
shift_key.gif 1
Toggle picking of mesh edges.
shift_key.gif 2
Toggle picking of mesh faces.
shift_key.gif 3
Toggle picking of mesh hexes.
F5
Refresh graphics window
shift_key.gif S
Activate/inactivate graphics clipping plane
