The following commands list mesh entity information.
List {Hex|Face|Edge|Node} <id_range>
List {Hex|Face|Edge|Node} <id_range> IDs
For both of these commands, the range can be very general, following the general entity parsing syntax. The first command provides detailed information. For an entity, the information includes its id, owning geometry, subentities and superentities. For a hex, the Exodus Id is also listed. For a node, its coordinates are listed. The second command just lists the entity ids, and is usually used in conjunction with complex ranges.
