Drawing a Location, Direction, or Axis
Some commands require you to specify a location on a curve (i.e., webcutting with a plane normal to a curve). This location can be previewed with the following options:
  1. A fraction along the curve from the start of the curve, or optionally, from a specified vertex on the curve.
  2. A distance along the curve from the start of the curve, or optionally, from a specified vertex on the curve.
  3. An xyz position that is moved to the closest point on the given curve.
  4. The position of a vertex that is moved to the closest point on the given curve.
Draw Location On Curve <curve id> {Fraction <f> | Distance <d> | Position <xval><yval><zval> | Close_To Vertex <vertex_id>} [[From] Vertex <vertex_id> (optional for 'Fraction' & 'Distance')]
Some commands require a specified axis (such as webcut with a cylinder) and it is sometimes advantageous to view an axis before modifying geometry. To draw a preview of an axis use the following command:
Draw Axis {options}
Some commands require a specified location or point (such as create curve spline) and it is sometimes advantages to view a location before modifying or creating geometry. To draw a preview of a location use the following command:
Draw Location {options} [color <color_name>] [no_flush]
Some commands require a direction. To draw a preview of a direction, use the following command:
Draw Direction {options} [from] [location {options}]
Similar commands for drawing lines and polygons may also be useful.
