Command sequences can be written to a text file, either directly from Coreform Cubit or using a text editor. Coreform Cubit commands can be read directly from a file at any time during Coreform Cubit execution, or can be used to run Coreform Cubit in batch mode. To begin and end writing commands to a file from within Coreform Cubit, use the command
Record '<filename>'
Record Stop
Once initiated, all commands are copied to this file after their successful execution in Coreform Cubit.
To replay a journal file, issue the command
Playback '<filename>'
Journal files are most commonly created by recording commands from an interactive Coreform Cubit session, but can also be created using automatic journaling or even by editing an ASCII text file.
Commands being read from a file can represent either the entire set of commands for a particular session, or can represent a subset of commands the user wishes to execute repeatedly.
Two other commands are useful for controlling playback of Coreform Cubit commands from journal files. Playback from a journal file can be terminated by placing the Stop command after the last command to be executed; this causes Coreform Cubit to stop reading commands from the current journal file. Playback can be paused using the Pause command; the user is prompted to hit a key, after which playback is resumed.
Journal files are most useful for running Coreform Cubit in batch mode, often in combination with the parameterization available through the APREPRO capability in Coreform Cubit. Journal files are also useful when a new finite element model is being built, by saving a set of initialization commands then iteratively testing different meshing strategies after playing that initialization file.
