Debugging Geometry
The following command checks for inconsistencies in the Coreform Cubit topological model, by checking the specified entities and all child topology and/or comparing to solid model topology:
Geomdebug Validate [compare] <entity_list>
This command checks for:
Related Commands:
Geomdebug Vertex <vertex_id>
Geomdebug Curve <curve_id>
Geomdebug Surface <surface_id>
Geomdebug body <body_id>
Geomdebug Containment {Curve | Surface} <id> {Location (options) | Node <id_list>}
The following command prints info about GeometryEntities owned by specified entity:
Geomdebug Geometry <entity_list> [interval <n>] [index <n>] [TEXT] [GRAPHIC] [attributes]
The following command lists (TopologyBridge) topology for specified entity:
Geomdebug solidmodel <entity_list> [index <n>] [depth<n>|up<n>|down<n>]
The following command lists GroupingEntities.
Geomdebug GPE <entity_list>
