Importing STEP Files
The ACIS STEP translator provides bi-directional functionality for data translation between ACIS and the file format standard STEP AP203.
STEP AP203 is an international standard which defines a neutral file format for representation of configuration control design data for a product.
The command used to import a STEP file are:
Import Step '<step_filename>' [No_bodies][No_surfaces] [No_curves] [No_vertices] [HEAL|Noheal] [Logfile ['filename'] [Display]] [Show_Each] [Group {'<name>'|<id>}] [Sort] [XML '<xml_filename>']
Import Options
Import Settings
By default, names on bodies in STEP files are not read in. To change this, the following command is available:
[set] Read Step Body Names [on|OFF]
Exporting a STEP file from Pro/Engineer
To export a STEP file from Pro/ENGINEER, from the Export STEP Dialog, Press Options.
In the file step_config.pro add the following:
STEP_EXPORT_FORMAT AP203_CD.
Also be sure your export option is set to Solids. If the geometry has problems in Coreform Cubit, you may need to increase the geometry accuracy in Pro/ENGINEER.
See also Exporting STEP Files.
