The command to import a mesh from an Abaqus format file is:
Import LSDyna [Mesh Geometry] '<input_filename>' [Feature Angle <angle>] [nobcs]
Including the keyword Mesh Geometry will instruct Coreform Cubit to create mesh-based geometry. This will provide the user with the ability to remesh geometric entities. If the user does not import with the Mesh Geometry flag, he will have to tell Coreform Cubit to draw the mesh after the import is done in order to view it.
The keyword nobcs can be included if boundary conditions are not to be imported.
It should be noted that Coreform Cubit sometimes cannot successfully generate mesh-based geometry for complex models. If this occurs, import the mesh without the Mesh Geometry flag, and draw the mesh to view it..
Table 1. Supported Element Types
Cubit supports reading LS-Dyna cards , ELEMENT_SHELL, ELEMENT_SOLID, ELEMENT_BEAM. These types will create BEAM, SHELL, TETRA, HEX, WEDGE, and PYRAMID elements based on the type and the number of nodes. Higher-order elements are supported with the exception of PYRAMID. LS-Dyna does not support a higher-order pyramids. Cubit will also create elements for the following options. Note that not all data is supported in Cubit. Some option data may be lost during translation.
LS-DYNA Element Type |
LS-Dyna Options |
ELEMENT_SHELL |
OFFSET |
ELEMENT_SOLID |
ORTHO |
ELEMENT_BEAM |
PID |
See https://lsdyna.ansys.com/ for more information on the LS-DYNA file format.
