The command to import a mesh from an Abaqus format file is:
Import Abaqus [Mesh Geometry] '<input_filename>' [Feature Angle <angle>] [Nobcs]
Including the keyword Mesh Geometry will instruct Coreform Cubit to create mesh-based geometry. This will provide the user with the ability to remesh geometric entities. If the user does not import with the Mesh Geometry flag, he will have to tell Coreform Cubit to draw the mesh after the import is done in order to view it.
The keyword nobcs can be included if boundary conditions are not to be imported.
The Abaqus importer can import the following Abaqus file formats: flat file, part-independent, and part-dependent.
It should be noted that Coreform Cubit sometimes cannot successfully generate mesh-based geometry for complex models. If this occurs, import the mesh without the Mesh Geometry flag, and draw the mesh to view it.
To list Abaqus cards supported by Coreform Cubit:
List Abaqus Import Cards
This command will list out all supported Abaqus cards that Coreform Cubit can interpret.
Table 1. Supported Element Types
1st Order |
2nd Order |
Triangle |
S3 |
STRI65 |
Quadrilateral |
S4 |
S8 |
Tetrahedron |
C3D4 |
C3D10 |
Hexahedron |
C3D8 |
C3D20 |
Line Element |
B21 |
B22 |
See http://www.simulia.com/ for more information on the ABAQUS file format.
