Importing Nastran Files
The command to import a mesh from an Nastran format file is:
Import Nastran [Mesh Geometry] '<input_filename>' [Feature Angle <angle>] [Nobcs]
Including the keyword Mesh Geometry will instruct Coreform Cubit to create mesh-based geometry. This will provide the user with the ability to remesh geometric entities. If the user does not import with the Mesh Geometry flag, he will have to tell Coreform Cubit to draw the mesh after the import is done in order to view it.
The keyword nobcs can be included if boundary conditions are not to be imported.
It should be noted that Coreform Cubit sometimes cannot successfully generate mesh-based geometry for complex models.  If this occurs, import the mesh without the Mesh Geometry flag, and draw the mesh to view it.
See http://en.wikipedia.org/wiki/Nastran for more information on the NASTRAN file format.
