Internally, Coreform Cubit represents geometry as either ACIS solid model geometry or mesh-based geometry. Coreform Cubit can import ACIS geometry in the native "sat" file format. Coreform Cubit can also import STEP and IGES files and internally converts them into ACIS solid model geometry. For compatibility with Sandia legacy applications, Coreform Cubit can import FASTQ input decks to create ACIS geometry, as well. Coreform Cubit also contains experimental support for using SGM for representing geometry.
If you have geometry that has been created in another format, such as in SolidWorks, you will need to translate that geometry into something that Coreform Cubit can read. Many solid modeling packages have an Export ACIS .sat command, which is probably the easiest way of translating your model. If you do not have that option, there are some other possibilities.
See Also
