CL Basic Tutorial Step 10
Step 10: Defining Boundary Conditions
Let us assume that we need to define one material type for the entire mesh, and a single node-based boundary condition on all surfaces. This is accomplished by identifying an Element Block and a Nodeset, respectively; the id numbers assigned to these entities are assigned by the user, usually by some convention meaningful to the analysis to be done. The element block and nodeset are identified using the commands:
Coreform Cubit> block 100 volume 1
Coreform Cubit> nodeset 100 surface all in volume 1
