Drop Down Menus
The Coreform Cubit Drop-Down Menus, located at the top of the Coreform Cubit Application Window provide access to capabilities such as file management, checkpoints, display manipulation, journaling, system setup, component management, window management, and help.
Coreform Cubit (Mac Only)
This menu contains the Preferences dialog box, also called the Options dialog box on other platforms. It also contains the About Coreform Cubit menu and the Quit Coreform Cubit option. It is only available on Mac computers.
File
This menu provides common file operations, including importing and exporting of geometry and meshimport and export. A list of recently saved or imported files is also provided, allowing a quick way to import current or recent work. Non-Mac users can also exit and reset the program from this menu (These options are found under the Coreform Cubit tab for Mac Users).
Edit
This menu only provides a way to enable the Undo feature of the system. If Undo is enabled, one level of Undo is available to the user.
View
The View Menu lists all available toolbars and windows in the current Coreform Cubit session. Selecting a toolbar or window will make it visible. Deselecting a toolbar or window will hide it. You can also hide an undocked window or toolbar by clicking on the small "x" in the upper right corner. For more information on docking and undocking toolbars, see Coreform Cubit Application Window.
Display
The Display Menu controls display options for the graphics window. These options are explained below:
Tools
The Tools Menu contains access to GUI-specific tools and options. These options are explained below.
Help
